Discussion in "General help Guidance and Discussion" started by    pravin_35    Apr 8, 2010.
Mon Jul 16 2012, 12:49 pm
#41
@smandys
more... programming level or application level or basics which one you want??
Tue Aug 21 2012, 04:08 pm
#42
so pravin please elaborate more..
Wed Nov 07 2012, 05:53 pm
#43
hi Smandy,
Apologies for the late Response
I recommend you to download the software which is available in www.ni.com and there you can find More example and Start up frame works. If you need more got To Decibel.ni. There you Can find lot of Stuffs Related Ni And Labview
Mon Apr 22 2013, 11:15 am
#44
hi guys,
LabVIEW Interface for Arduino Setup Procedure
Setting up the LabVIEW Interface for Arduino is a six step process that you will only need to complete once. Please follow the instructions below to start creating applications with the LabVIEW Interface for Arduino.
(For a brief overview of the LabVIEW Interface for Arduino see Michaels post here).
1. Install LabVIEW
If you purchased the LabVIEW and Arduino bundle from Sparkfun.com you can install LabVIEW from the included DVD.
If you do not own a copy of LabVIEW you can download and install the 30 day evaluation version here.
2. Install the NI-VISA drivers.
Windows Download.
Linux Download.
Mac Download.
3. Install JKI VI Package Manager (VIPM) Community Edition (Free).
All Operating Systems.
4. Install the LabVIEW Interface for Arduino as described in KB 5L38JQYG
5. Connect your Arduino to your PC as described in KB 5INA7UYG
6. Load the LabVIEW Interface for Arduino Firmware onto your Arduino as described in KB 5LPAQIYG
(We are working to fix the above document. The firmware can be found in <LabVIEW>\vi.lib\LabVIEW Interface for Arduino\Firmware\LVIFA_Base . Use the arduino IDE to deploy this firmware to your Arduino.)
note:( KB 5L38JQYG) use this code in ni site to find instruction
https://decibel.ni.com/content/groups/labview-interface-for-arduino?view=documents (example codes for arduino)
You are now ready to use the LabVIEW Interface for Arduino.
[ Edited Mon Apr 22 2013, 02:09 pm ]
Mon Oct 28 2013, 08:46 pm
#45
hi.....i am using visa library for serial communication ..and i am getting error like................
VISA: (Hex 0xBFFF000E) The given session or object reference is invalid..
what it means..........
Mon Oct 28 2013, 09:19 pm
#46
sir can i have a link! where can i download sir. want to learn this too.
Tue Oct 29 2013, 12:07 pm
#47
vijay.parmar1992
Hi,
whenever you try to do serial communication make sure that you have COM available on MAX(Measurement Automation Explorer).
Error symptoms Might Be a unproper code without delay or configuring the Com in your Pc.
What ever code you have done needs some basic things
A) Whenever you use While loop Make a delay of Milli sec Timer ...
B) give delay between read And Write if you doing Async ly...
C) Check the examples to learn how to make a good architecture ....
https://decibel.ni.com/content/docs/DOC-16720 serial Library you can make use of the Code for Serial communication..
Let me know any thing Required..
Thanks & cheers
[ Edited Tue Oct 29 2013, 12:10 pm ]
Tue Oct 29 2013, 12:12 pm
#48
engr1931
Hi,
you Can download the Evaluation Version From http://india.ni.com/
Are some Student version is Also available contact Ni..
Regards
Pravin
HenryLaf
Mon Apr 22 2024, 03:50 pm
bleradrar
Mon Apr 22 2024, 06:38 am
ppu-pro_ka
Sun Apr 21 2024, 07:39 pm
Infewow
Sun Apr 21 2024, 06:30 pm
